atomsplitter
- Joined
- Nov 29, 2007
- Messages
- 4,331
- Location
- Keller, TX
- Ride
- 23 Rocket GT, 20 Bobber Blk, 22 Speed Triple RS
Yes, use TuneECU and read any DTC codes. If DTC P1575 is active the cruise control switch check is still required. The on-screen dialog box will state perform a switch check. If you don't have the 1575 code, then something else is going on. When you do the switch check make sure you are going full travel with each switch. I highlighted the adaptations because if all you do is reset adaptations and nothing else with TuneECU, you must perform the switch check to restore cruise control.No Unless im doing something wrong? Just test drove it and tried several times. Is there a confirmation that it works?
From the service manual:
Cruise Control Switch Check The cruise control switch check is required after certain DTCs or defects have been repaired which relate to the ride by wire system or cruise control system, or after the adaptions have been reset.
The switch check requires the user to operate the switches in order, following the instructions on screen.
The following switches will be checked:
• Front brake switch
• Rear brake switch
• Clutch switch
• Twist grip cruise cancel switch (operated by holding the twistgrip in the fully closed position)
• Cruise control accelerate switch
• Cruise control decelerate switch.
A malfunction of any switch will not necessarily cause a DTC to be stored and may prevent the cruise control from operating correctly.
Note • If the cruise control switch check is not carried out, the green cruise control warning light will illuminate when the ignition is turned to the ON position but the cruise function will be disabled.
