Journeyman
Look in the Resources tab at the top pf the page.I believe there is a service manual in this site somewhere . Perhaps another member knows where
Looked up in the shop manual:
P1640- Roll Over detection disabled due to Inertial Measurement Unit (IMU) malfunction
P1695 - CAN fault - lost communication with instrument panel
P16A2 - Engine ECM detects IMU present but with signal error
It points to the IMU having a problem. If the fault is cleared after 40 start cycles the MIL light will clear or just use TuneECU and clear them and see if they come back.
Shop Manual Instructions:
Make sure ABS modulator connector is secure. Check for associated DTC C1713, perform tests for this DTC. Reset DTCs, if problem persists contact Triumph service.
Description of system:
IMU (if fitted) The Inertial Measurement Unit measures the following:
• Longitudinal acceleration
• Vertical acceleration
• Lateral acceleration
• Pitch rate
• Yaw rate
• Roll rate
From these measurements the IMU calculates the motorcycle's lean angle. The IMU outputs are used for multiple systems, for example, optimised cornering ABS (OCABS) and fall detection. If the IMU is fitted, the fall detection switch will not be fitted.
Here Comes the Bad News:
On the Rocket 3, the IMU is mounted on the frame (typically under the tank or near the ABS modulator). Replacement involves:
1. Remove bodywork to access the IMU
Usually:
The IMU is a small rectangular sensor with a single multi‑pin connector.
- Seat off
- Tank lifted or removed
- Side panels off
2. Disconnect the IMU harness
Triumph uses locking connectors — depress the tab and slide the connector out.The manual specifically tells you to verify the ABS modulator connector is secure when diagnosing IMU faults , because the IMU shares CAN communication paths.
3. Unbolt the IMU
It’s mounted with 2–3 small bolts.Important: The IMU must be mounted perfectly level. Triumph uses fixed mounting points so alignment is automatic.
4. Install the new IMU
Bolt it in, reconnect the harness.
5. Clear DTCs and verify communication
The manual says:
This is because the IMU is part of the CAN network, and the ECM must detect it and validate its signals.
- Clear DTCs
- If the problem persists, contact Triumph service
6. Perform IMU calibration (dealer tool only)
Triumph’s diagnostic system (Triumph OBD/DealerTool) performs:
TuneECU cannot perform IMU calibration — it can only clear codes.
- IMU initialization
- Zero‑angle calibration
- CAN handshake
Your current tab shows the IMU‑related fault codes:
These codes strongly suggest:
- P1640 – Roll‑over detection disabled due to IMU malfunction
- P1695 – CAN fault, lost communication with instrument panel
- P16A2 – ECM detects IMU present but with signal error
Because the IMU is part of the safety system (cornering ABS), Triumph requires calibration after replacement.
- Either the IMU is unplugged, water‑damaged, or internally failed
- Or the CAN line between IMU → ABS modulator → ECM is compromised
Here's The Good News:
Before replacing the IMU, check these first
These are directly from the manual:
A loose ABS connector is far more common than a failed IMU.
- Check ABS modulator connector (IMU shares CAN path)
- Check for DTC C1713 (ABS/IMU communication fault)
- Clear DTCs and see if they return
Correct, it's a place to start. And probably should be consulted before posting here. What I don't want to see is a post go unanswered like no one cares or is too trivial. I am also happy to share what I've learned over the decades of Triumph ownership, but that doesn't mean I know everything there is to know about every model. If it gets the community talking and working together for a problem solution, I'm thinking I did my part to help a brother (sister). And I have posted a few times some very technical answers (which are usually very long and very detailed (including the math and formulas)). But I get your point, I'll try not to post just an AI in future.Hey! Just a small request—would you mind not replying with just "AI" to technical help posts? People are usually looking for actual solutions, so if you have any advice or experience to share, I'm sure it'd be really appreciated.
Sure, AI can be helpful on a surface level, but what's next? Has it actually read the entire 1,500-page factory service manual for that specific model? Has it understood the procedures, service bulletins, and model-specific quirks? AI is a tool, not a substitute for technical knowledge or experience.
you are lucky it didnt fry your instrument dash,I took apart the rear blinker as I saw my left blinker was bent and the wires were pulled on. took it apart and put it back together. Took the seat off and reconnected the battery after having it off for about 36hrs (due to the bike making a weird whining noise). hit the power switch, cleared the fault codes, turned the bike off and back on, and started the engine. Codes were gone! Must have been a short somewhere possibly near the rear blinker? Very strange.
That's a good idea. Might end up doing that.you are lucky it didnt fry your instrument dash,
there is no relay running blinkers on rocket 2.5, blinkers are being turned on/off from instrument cluster by chip inside instrument, so any short in blinkers will fry instrument
I have been there and done that, replacement was 1500USD
I have installed fuses in on rear blinker power rail to make sure instrument never burns again
I enjoy your responses and replies, and with any reply everyone needs to think, follow up.Correct, it's a place to start. And probably should be consulted before posting here. What I don't want to see is a post go unanswered like no one cares or is too trivial. I am also happy to share what I've learned over the decades of Triumph ownership, but that doesn't mean I know everything there is to know about every model. If it gets the community talking and working together for a problem solution, I'm thinking I did my part to help a brother (sister). And I have posted a few times some very technical answers (which are usually very long and very detailed (including the math and formulas)). But I get your point, I'll try not to post just an AI in future.
