Still rear light / number plate light woes
HIM57
.040 Over
Rancho Cucamonga, CA
2008 Triumph Rocket 3 Classic
I have detached everything except the number plate light which only has 2 wires (red and black) I have connected to the yellow and black on the bike harness side and still no number plate light (red to yellow black to black)
If I go direct to the battery - light works fine.
If I connect the light and flashers - brake light and flashers work fine. I did replace the relay prior to putting the LED light on.
Is the yellow black from the bike on a separate relay? Does is need to be changed as well as the flasher relay to accommodate the LED running and number plate light? Just seems like there is no power off these wire and I don't have a voltmeter.
Thanks again anyone.
