Starter won't turn engine over
Discussion in 'General Tech Talk' started by Justin Lakes, Jul 11, 2019.
Tags:
  1. warp9.9
    warp9.9 Pocałuj mnie w dupę
    8,790
    Featured Threads:
    9
    Media:
    14
    10,883
    823
    Forest City Illinois
    Ride:
    07 Rocket
    No special tool ive seen it done with a telescopic magnet
    I use a pair if hemostats. Going back I use the same but a hose on tbe end of the plug would work also. I believe the standard spark plug socket won't work its outside diameter is to big because it has the rubber stuffed in it.
    Jvheli likes this.
  2. Jvheli
    Jvheli Turbocharged
    Country:
    United States
    654
    Featured Threads:
    11
    1,096
    103
    Milwaukee, Wisconsin
    Ride:
    2016 Rocket Roadster
    Agree. The only socket I’ve found that works is in the supplied tool kit. Basically a sheet metal socket.
    Claviger likes this.
  3. warp9.9
    8,790
    Featured Threads:
    9
    Media:
    14
    10,883
    823
    Ride:
    07 Rocket
    Ya I just use a 3/8 drive deap well socket then go retrieve the plug.
    ozrider and Joesmoe like this.
  4. Joesmoe
    Joesmoe IMOKUR2 Staff Member
    Country:
    United States
    3,834
    Featured Threads:
    42
    Media:
    5
    4,863
    823
    Fairfax, Virginia
    Ride:
    Triumph: 2014 Rocket III Touring
    Yep, that's what I did. +1
  5. R-III-R Turbo
    R-III-R Turbo Warp Speed: ENGAGE
    1,002
    Featured Threads:
    26
    Media:
    85
    1,784
    223
    Ireland
    Ride:
    '10 Supercharged Carpenter'd Roadster, 04 Hayabusa
    Same here, deep 18mm hex socket 3/8th drive, but with a rubber grommet glued into it to hold into the plug's ceramic tower.
    @Justin Lakes good you're now on the right track. Is there a gap between pulley & engine front?
    Bearing ok in the crank spigot bearing housing?
    [​IMG]
  6. Justin Lakes
    Justin Lakes .020 Over
    Country:
    United States
    50
    16
    8
    Connersville, Indiana
    Ride:
    2007 Triumph Rocket iii Classic
    I'll check today. I walked away from it last night. Thanks for the depth pic, I was wondering what it should be
  7. 1K9
    1K9 Big Cruisers 4 Me
    Country:
    United States
    2,789
    Featured Threads:
    1
    Media:
    16
    2,899
    823
    Clear Lake / Houston, Texas
    Ride:
    2007 Rocket III
    How did the injectors open to fill the cylinders with gas? :thumbsdown:
    On the Valkie I had an electric valve cut-off installed to prevent that. Switch ON opens the fuel flow, switch OFF, fuel off. If that were to happen on the Valkie it would become road kill Vulture food and it would make me cry. I get separation anxiety when I leave the Valkie at the shop.
  8. warp9.9
    8,790
    Featured Threads:
    9
    Media:
    14
    10,883
    823
    Ride:
    07 Rocket
    They didn't re-read the post Polock :D
    Kevin frazier likes this.
  9. Kevin frazier
    Kevin frazier Widow maker Nashvegas
    Country:
    United States
    812
    Featured Threads:
    2
    993
    203
    Nashville
    Ride:
    2008 Triumph rocket 3 touring
    Getting good now
  10. Mad Dog
    Mad Dog Supercharged
    Country:
    United States
    209
    Featured Threads:
    4
    Media:
    2
    351
    73
    Oklahoma City, Oklahoma
    Ride:
    2008 Rocket III Touring
    I’m not sure but I think he just called you a Pollock.
Loading...
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    By continuing to use this site, you are consenting to our use of cookies.
    Dismiss Notice
