Starter won't turn engine over
Discussion in 'General Tech Talk' started by Justin Lakes, Jul 11, 2019.
Tags:
  1. Justin Lakes
    Justin Lakes .040 Over
    Country:
    United States
    51
    16
    8
    Connersville, Indiana
    Ride:
    2007 Triumph Rocket iii Classic
    I can hear it engage, but it won't turn it over.
    You can hear the struggle
    Have to be careful because the starter and pos battery cable will get hot quick
    Battery has 12 volts
    Added jump pack
    Added jumper cables from truck
    Removed battery and just used jump pack
    Put bike in gear trying to rock it back and forth, thinking something was stuck
    Removed starter and bench tested it and it worked fine.
    .... I'm puzzled
  2. Joesmoe
    Joesmoe IMOKUR2 Staff Member
    Country:
    United States
    4,290
    Featured Threads:
    45
    Media:
    7
    5,791
    823
    Fairfax, Virginia
    Ride:
    Triumph: 2014 Rocket III Touring
    That sure doesn't sound right.
    Curious about bench testing the starter -- if the solenoid engages and the motor spins against no load, how do you know it's good ?
    And rocking the bike -- in 5th gear right ? (for maximum mechanical advantage for the rear wheel) -- what did it do ?
    And trying to start -- of course you have it in neutral -- and/or clutch pulled ?
    Dunno if you're in a convenient place -- could remove the crank inspection port on the front of the motor, and attempt to turn the motor by hand -- could remove three spark plugs to insure not working against compression.
  3. Kevin frazier
    Kevin frazier Widow maker Nashvegas
    Country:
    United States
    1,867
    Featured Threads:
    14
    2,839
    323
    Nashville
    Ride:
    2008 Triumph rocket 3 touring
    TTS sc done? This is a test run? All good before TTS install I take it. Could be that starter isn’t going to get job done cranking that thing now or something simple as in loose ground somewhere maybe.
    Boog likes this.
  4. Joesmoe
    Country:
    United States
    4,290
    Featured Threads:
    45
    Media:
    7
    5,791
    823
    Fairfax, Virginia
    Ride:
    Oooh, good point, and good memory. I had forgotten the previous history.
    Justin Lakes and Kevin frazier like this.
  5. Justin Lakes
    Country:
    United States
    51
    16
    8
    Ride:
    In 5th gear the tire just slid and I only weigh 160 lbs so there wasn't much happening
    I took starter off and applied voltage to it to see it mechanically work.. no real world application (no load)
    Yes in neutral and clutch pulled
  6. Justin Lakes
    Country:
    United States
    51
    16
    8
    Ride:
    This was supposed to be the test start... this thing has fought me the entire way. Ground appears to be good. The bike is immaculate and low miles. 0 corrosion.
    Boog likes this.
  7. Kevin frazier
    Country:
    United States
    1,867
    Featured Threads:
    14
    2,839
    323
    Nashville
    Ride:
    Can you double up on cables pos and neg to starter and engine ground, there’s also a starter upgrade @warp9.9 has posted, I have pictures if you need of starter, it’s a 2.5l toyota and you just change gear and plunger over
    Boog likes this.
  8. Kevin frazier
    Country:
    United States
    1,867
    Featured Threads:
    14
    2,839
    323
    Nashville
    Ride:
    And you said 12v, was that with ignition switch engaged 12 what seems high on contact, did you have battery tender hooked up while installing sc?
  9. Justin Lakes
    Country:
    United States
    51
    16
    8
    Ride:
    I could probably double up on cables temporarily to see
    It just blown my mind that it doesn't even entertain the thought of budging
  10. Kevin frazier
    Country:
    United States
    1,867
    Featured Threads:
    14
    2,839
    323
    Nashville
    Ride:
    Put some juice to her
    Justin Lakes likes this.
Loading...
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    By continuing to use this site, you are consenting to our use of cookies.
    Dismiss Notice
