Spring recommission!
Jag
Cape May Co. NJ
2013 R3T
Spring is here, don’t forget the most overlooked maintenance item on your bike! Blinker fluid change!
Also don’t forget to let all the old stale air out of you tires and refill with new fresh air!
Get out your metric adjustable and have fun getting your bike ready fo the riding season!
Can I substitute Fork Oil for the Blinker Fluid ? I really don't want another bottle of fluid that comes in 32oz bottle that I only need 4oz a year. Kind of goes stale before I can use it all.
Remember and bleed your brakes, just use tap water as long as you do not apply pressure and heat the water up the brakes will work fine.
Adding table salt will raise the boiling point
Don't forget to grease the rotors, armor-all the tires, and freshen up the muffler bearings
