Want to Buy Sissy bar pad wanted
Bigjaype
I'll eat Sonny's sandwich...
Narre Warren North
R1200GS
Does anyone have or know of a sissy bar pad that fits the Triumph sissy bar that is bigger than the standard?
Alternatively, a taller sissy bar that will use the same pad? Wifey complains that the current sissy bar pad digs too low Into her back when my right hand suffers from dropped wrist syndrome!
Thanks in advance....
Should a sung out earlier - I have a brand new TALL sissy bar AND a large backrest pad if required.
There was accessory Classic pad that came with some Classic models and fits the same Roadster sissy bars. Just took one off my Roadster. Looks like you may already have one on your Classic in the avatar photo.
The Standard back rest pads are much smaller.
SISSY BAR BACKREST
- STANDARD
A9701144
SISSY BAR BACKREST
- TOURING
A9701145
SISSY BAR BACKREST
- CLASSIC A9708117
They are still available in Oz but expensive.
BACKREST PAD - ROCKET 3
  • $182.17
The Classic Sissy Bar Backrest A9708177 is to be used with the Quick Release Sissy Bar Kit A9750516 as well as Tall & Short Sissy Bar & Rack kits A9738070 & A9738071. This item fits Rocket III Classic and Rocket III Roadster models.
Fits
  • Rocket 3
  • Rocket 3 Roadster
  • Rocket 3 Classic
  • $182.17
Qty
I also have a large Corbin leather covered one off an early Goldwing that could easily be fitted for a lounge chair back. I have multiple leather hides in different colours and hide patterns to choose from to cover the back if used on an open style sissy bar.
It has two little 1" metal rivetted tabs (one is surface rusty) at bottom of back to engage slots or similar on the Goldwing top case but these can be easily removed.
33cm wide at base where beading finishes, widest point 36cm, 34 high, thickest cross section just under 6cm.
Well it says R3T actually, the removable rack and the pad is out of stock anyway.
The removable rack is not interchangeable with R3Rs and the pad could be forced to fit but may end up with extra holes.
The Roadster/Classic fitting rack:
TALL SISSY BAR/LUGGAGE RACK A9738070
Requires a Sissy Bar Backrest Pad (Does not inlclude Sissy Bar Badge A9738002)
The removable R3T rack
QUICK RELEASE SISSY BAR - CHROME A9758067
Lockable, supplied with 2 keys Can be matched to bike’s ignition
Requires Rear Fender Trim Kit A9758075 and Sissy Bar Back Rest Pad
TOURING BACKREST PAD - PILLION A9708165
For use with Quick Release Sissy Bar A9758067
The other R3Touring pillion pad is the LONGHAUL BACKREST PAD - PILLION A9708159
