canecorso
The custom seat man
I'm going to attempt to wire up my back signals I just bought, I made the bracket out of stainless steel.
Took off the chrome cover and noticed the two screws that screw into the fender was loose so I went to tighten them and they keep on turning? They will not tighten, is it just a thread through the fender? That could be striped? I looked under the fender hard to tell should there be a nut? I felt with the fingers and seem the scew keeps on turning and doesn't seem like there is a bolt?
As any one came across this? And how did you fix it? If I take the screw out seem like that brake is attached with the spring and I could be in a bigger problem.
And also is there any one that has step by step on how they wired it up the two back signals, and what colour wires is for the singnals? How do you hide the wires so there not seen? Or hanging over tire?
Should I use the wire on side showen that was the connection to my trunk for singnals and brake lights.
And the other side do I run the wires from under fender?and how do you prevent wires from hanging?
It seems there's only wire brackets that are in the middle under fender.
I'm a visual person so any pictures of videos will for sure help me.
