TURBO200R4
stand up straight and grab the world by the a$$
Thanks you guys I'll give it a try tomorrow.
I guess the easiest would be to run some wire up to the front left signal and run wire up to the right signal and then hook them up![]()
that sounds like a bad idea.
u could run your bike over to a place that wires trailers to trucks he could probe (a little gismo that pierces the rubber and makes contact with the wire inside of the rubber) the wires and mark them for u then u could just splice them or buy the meter an probe the wires yourself.
i would use a probe however u could shave a little piece of rubber off of each wire and stagger the cuts. of coarse check them after each shaved wire u may get lucky and get the right ones after a couple.
of coarse if u waved $30 in front he might wire them up for u.
