MikeW
Banner Elk, North Carolina
2012 Rocket Roadster
I am hoping some of you can give me advise on what to do set-up wise on my 2012 Rocket Roadster. I am running ram air with cut bearclaw which I did a 12 minute tune on. I just bought a set of TORS and a staintune crossover pipe. I want to run the TORS because the bike has Corbin bags and fairing on it and the TORS run to the back of the bags. For me it looks better with the pipes running to the back of the bike and not terminating in the middle of the bags. I am not doing this because I need alot of HP the bike will already smoke most all HD's I encounter. I just want it to sound a little better. I live in the mountains of North Carolina so the closest Triumph dealer is in Kingsport Tenn. I am not a big computer guy (i'm old) so I want this to be easy. My questions are:
1. Tuneboy, Tune ECU, PCV, or just get stock ECU re-flashed.
2. If I use the power commander V can I just install it myself and not need a dyno or ECU re-flash.
3. Could I just use a 12 minute tune after I install the TORS and staintune crossover?
I really appreciate the help.
Mike W
Get with @HansO ...I'm sure he has a map for Ram Air, TORS and a Xover pipe, then just load with TuneECU and enjoy. If he doesn't have a map I'm sure somebody on here does.
Find a competent tuner and DYNO the sucker using Tune ECU then fagetaboutit!
You need a Windows laptop or an Android tablet to load tunes with TuneECU. You can get a cable for TuneECU on Amazon and an extension cable for an Android from ??. TuneECU is free on TuneECU.com for Windows and $$ as an app for Android. Then maybe Hanso will send you a tune. Do you have any dyno tuners nearby?
