yeah thats the same as Les has and apart from having to widen the front bit works a treat, I believe he paid a lot more then that, I'm keen to know more
just looked at the site and they advertise it for $79.99 if you become a member or $99.99 otherwise and I just joined, it is free to join and $15.00 for shipping, $94.99 is still a good price ..... So Thanks @dave64 for posting your find
Oh and for joining you get a $10 discount as well si it ended up being only $84.99
The stand will need a little modification on the top clamp as it is not wide enough for the 150mm tyre, i will have a play with it on the weekend and see what mods are needed to make it secure .
as I mentioned in post #3 @ozrider Les widened his maybe he can post a picture to give you a guide as he did a top job on his I will be doing a simple cut and weld wider centre section in front section job on mine when it arrives (Thanks Again for posting thread, Dave), I bought an Aldi one already but will just use it for Ann's little GPX 250 as it would need the bottom section to be modified as well before I would be happy to put my big girl in it
I'm not sure yet , but i may have to allow the wheel to go further into the stand to allow the swivel clamps to lock in. So it may need the front upright with vee channel moved forward as well as a bigger vee channel .But if you have a smaller tyre width or lower profile this may not be a issue.
as @HansO said, I remade the front vee, the distance from the pivot to the front post was ok on mine,
The vee was 3 bits of flat plate welded together, I can send you some measurments if you want @dave64
