bozosl8
Standard Bore
- Joined
- May 31, 2008
- Messages
- 4
I have over 46K on Rocky - almost all on the darkside. While on the road, I will drop to 4th, even 3rd if I have to, keep the rpm above 3000 . Never had a problem. Changed the tires, brake pads, oil [Amsoil]/filter, and one fog-lamp bulb. A sparkplug wire gave me the fits for about 30 days, but that's the worst; just clipped about 3/8 of an inch off and stuck it back in the coil. Never busted a seal, and sure as hell haven't touched the valves. Commute everyday to the office. 10 BLOCKS! Rocky hates it. Two weeks of that karapp takes 200 miles at 3500+ to clean out. ROCKETDARYL - your "sweet spot" may be 73-75 but it's not that badboy's between your legs. Your just used to it. Rocky sounds like he's rappin' at 2800, but he's not. 90 is 3500. 100 is dead-on 4000. And, believe it or not, on a Rocket III you can get used to that, too. How long you can stand it is up to you, because everytime you shift into 5th, Rocky prays to Jesus that you're headed to 4. I don't know where Rocky's "sweet spot" is, but mine is somewhere between the back of the gas tank and the front of the passenger pad.
