Kevin frazier Widowmaker! Joined Dec 22, 2018 Messages 8,362 Location Nashville Ride 2008 Triumph rocket 3 touring Dec 22, 2018 #1 I’ve changed all 4 relays and the ems relay still drains battery and rocket 3 touring won’t start?
bigprop loud and alive Joined Aug 15, 2018 Messages 761 Location london uk Ride 08 rocket 3 classic ktm 990 Dec 22, 2018 #2 Hi and welcome from the UK you need our resident guru @DEcosse
IMFASTTOO Living Legend Joined Nov 23, 2008 Messages 4,394 Dec 22, 2018 #3 CHECK your cables connections on the battery they oxidize and loose connection its happened to me several times
Kevin frazier Widowmaker! Joined Dec 22, 2018 Messages 8,362 Location Nashville Ride 2008 Triumph rocket 3 touring Dec 22, 2018 #4 I’ll try to find him. I’m new here on forum, merry Christmas from Nashville
Kevin frazier Widowmaker! Joined Dec 22, 2018 Messages 8,362 Location Nashville Ride 2008 Triumph rocket 3 touring Dec 22, 2018 #5 IMFASTTOO said: CHECK your cables connections on the battery they oxidize and loose connection its happened to me several times Click to expand... Cables good and clean and tight
hoopla Mained to ride! Joined Jan 21, 2017 Messages 1,178 Location Maine, USA Ride 2022 Rocket 3 GT Dec 22, 2018 #6 Kevin frazier said: I’ve changed all 4 relays and the ems relay still drains battery Click to expand... how do you know the ems relay is draining the battery? You may just have a bad battery, even if it's relatively new. Test your battery by leaving the lights on for 10 minutes, should still be bright, not valid if you have leds for lights. Hoopla
Kevin frazier Widowmaker! Joined Dec 22, 2018 Messages 8,362 Location Nashville Ride 2008 Triumph rocket 3 touring Dec 22, 2018 #7 hoopla said: how do you know the ems relay is draining the battery? You may just have a bad battery, even if it's relatively new. Test your battery by leaving the lights on for 10 minutes, should still be bright, not valid if you have leds for lights. Hoopla Click to expand... When I pull the ems relay battery volts and cca hold with no drop with ems relay in battery drops like a rock. New battery battery is good
Kevin frazier Widowmaker! Joined Dec 22, 2018 Messages 8,362 Location Nashville Ride 2008 Triumph rocket 3 touring Dec 22, 2018 #8 Kevin frazier said: When I pull the ems relay battery volts and cca hold with no drop with ems relay in battery drops like a rock. New battery battery is good Click to expand... It won’t start, gauges won’t sweep when key turned on.
hoopla Mained to ride! Joined Jan 21, 2017 Messages 1,178 Location Maine, USA Ride 2022 Rocket 3 GT Dec 22, 2018 #9 Kevin frazier said: It won’t start, gauges won’t sweep when key turned on. Click to expand... What year Rocket? Bad ignition switch? Early Rockets had switches that corroded and shorted. Hoopla
Fingers Living Legend Joined Sep 30, 2014 Messages 2,919 Location Ocala fl Ride 2015 R3T Dec 22, 2018 #10 Welcome from Florida.Put your location and year,model in your avatar this will make it easier to give you assistance in the future.
