Boo hoo - my bike tipped over today. My wifes car was where I normally
park it to warm it up as I get my helmet on and close the garage door
so I parked it on a slight decline. With the heat, the kick stand sunk into
the pavement and you know the rest of the story.
In my opinion Rivco Engine Guards suck
They hardly broke the fall and it came down so hard the handle bars dinged my tank.
The engine guards did little to stop the shifter from bending in and causing the adjustment assembly to ding the motor.
The shifter was bent 45 degrees and was barely usable. I now have a mar
on the shifter bar from bending it back.
I also have scratches on the tank, tank emblem, clutch lever, handle
bar end cap, bear claw, foot peg, and many on the Jardine pipes.
Many of the smaller scratches should buff out and not be too noticable but the ding in the engine and tank should not have happened at all or at
least should have been less severe from an 80 degree tip over...
All the bars seem to do well is protect the radiator cover and they
are better than nothing at all for engine protection.
I was already concerned over the lack of leg space protection provided by
these guards and will be contacting them shortly to discuss improvements.
If they don't redesign them and swap mine out I will probably replace them with the newer Triumph ones as they appear like they would better
protect the rider, shifter and brake pedal.
Has anyone else experienced this level of damage with these engine guards after a minor tip over
