zimtuff
Nitrous
I repacked the jards a few months back which was great for few thousand klms.On the advice of a friend ,I used fire blankets cut to size and wrapped them up in adhesive backed foil.
But the loudeness come back and the popping got worse.
On top of that,the material expanded and jammed the baffles in so tight I could not pull them out with any thing in my shed,so I took them to the local exhaust shop.
They couldnt get the baffles to budge either,so I gave them permission to cut the pipes so they could bash them out.
Eventually they come out and I re wrapped them in rock wool ,a ceramic fibre based material,then did them again in adhesive backed foil and finished it off with wire wrapped around the baffle.
I took it for a ride and got the best sound ever,much of the popping has gone and the idle has improved.
Its a deep thump that is quieter and smoother than before but it hasnt lost any power/torque
Fingers crossed it will stay this way. At least the rock wool is thinner than my last effort,so I will be able to remove them easier.
