removing right side exhaust
How would you "close" the opening that goes to the pipe?
hammer? weld it shut?
be easier to just eliminate everything from the header back
and weld something you want on.
example below:
hope this helps.
skip
Closing the opening would be easy. However, the pipe on the left side is not level with either pipe on the right side (looking from the rear). Removing one of the right side pipes would really make it look uneven...
I have removed the lower pipe on the right side and capped the third outlet on the cat delete with a stainless pipe I welded together then put a slit into so I could clamp it on and then easily remove later. I have a PCV w/AT so I have no issue with dyno/custom tuning. I do not currently have access to my pics so I will have to post some in a few days.
I would think it could cause more back pressure so limiting the the top end but possibly raising the torque a little at lower end of your rev range:)
Well if it's not clean you've managed to pick yourself up a bit of 'not-dust' on the tank. Don't think it's permanent though. ;)
