remove indicator reflector from shell?
Mike Sands
County Durham England
roadster 2012
Anyone know how to do it (for the front ones)? I've bought a spare set that I want to paint matt black, but I can't see how to get the reflector out of the outer shell. It looks like it should rotate a couple of degrees but I can't get it to shift and I'm in danger of breaking the outer shell.
Thanks
Mike
Mike - I had to do the rear ones as they were wired in reverse - It makes a difference if you fit LED "bulbs". Get some fine SILICONE oil on those lugs and leave it a few minutes - Should rotate then.
