Rear wheel bolt pattern and offset??
20R3GT
.060 Over
2020 Triumph Rocket 3GT
Has someone swap rear wheel on new 2500cc rocket 3? Stock is 16x7.5 wide and 5 bolt!! Need to know offset and bolt pattern if someone did it ! I saw picture on fb left comment and guy never writes a specs on wheel!? Bolt pattern and offset please would be appreciated thx!!
Who is interested I find the bolt pattern is 5x120 Center bore 60mm and found two stamps on back off the wheel one says 11 another show 8 and also watch the storm new wheel design and also found 11 stamp and 23( assume this is production year) so 11 match in both wheels so I assume ET11! So need now see on eBay single wheel in 17x7.5 or 17x8 and see if I like something and than wheel adaptor to match ET11 and it can be swap to 240/45/17 tire or like I saw two guys 280/40/18 but I’m not that brave and it will looks wired probably with different sidewalls front 150/80/17 tire 280-260/40r18
Thanks, I was wondering about this recently myself. Had thoughts of fitting a rim from a car.
Turns out that the bead design of a car tyre/rim is different to those of a motorcycle. Strangely, it's closely enough that you CAN... but not for me unfortunately
