Allan S
Simple African lad with a Rocket
With the Hagons and every other brand you buy tell them your weight and usual riding style and load i.e. with or without pillion and how much of each 50/50 etc. With your weight you would not usually need a HD springs unless you carry a load or pillion regularly as spring preload should cover your needs well.
If you want increased cornering clearance and sharper steering response get an extra 0.5-1.0" of shock height from 12.5" stock.
Definitely get a fork spring upgrade and oil change as well to get vastly improved handling and fit a 140 width Michelin Commander or Avon Cobra front tyre next time with stock rear size or an Exedra 240/55 radial rear.
I really appreciate the time you took for such a detailed reply.. Thank you!!
