steelboss
.040 Over
Hi,
I am new to R3 and I have just bought a 2008 R3T. I have owned a number of rides since 1978 and my last was a Kawasaki 600 Ninja. I was all set to buy a Goldwing…something I had fantasized about for the past 30 years and the Goldwing “Deals Gap” video
(Google it) made me crazy to start touring. Anyway, I was concerned about the 2-wheeled Winnebago image and started looking at the Kawasaki GTR1400. And then I stumbled upon the Rocket…and the rest is history.
Ok, so I got the bike and I ride in China…absolutely wonderful touring through ancient villages, old stone bridges, temples, and farmland just breathtaking.
Except for the part where I twist back the throttle and the rear wheel spins like it was buttering a muffin.
Rear braking is horrifying unless you get a kick out if seeing your panniers moonwalking in the mirrors..
I am getting ready to get J-piped and Tune-jobbed so this spinning can only get worse. I spent 2 weeks ready R3 forums and I have rented a cubicle on the dark side.
A number if riders seem to agree that the Conti 205-60-16 is the tire of choice if you are willing to cross the void. So I did some checking on the world’s largest online shopping platform (based in China) and I found a tire that I think is better than the Conti. I studied the tread patterns on many (car) tires made by Dunlop, Bridgestone, Pirelli, Michelin, Goodyear, Yokohama, and a handful of other Western & Asian brands. Many of the tires do not have symmetrical patterns leading away from the center; meaning one side is different than the other = handling & wear differences depending on if you are leaning left or right??... For others, such as “large V” pattern sport radials, the spaces are too large, equaling less rubber; and then finally, others that have symmetrical patterns and good spacing, have a solid, unbroken centerline rib, which is not good for water shedding and traction at the center.
I decided to buy the Primacy LC 205-60R16 92V by Michelin. This tire is designed to be a gas-saver, super quiet, and softer sidewalls for cornering and extra comfort.
Specs:
Car Type • Passenger
Tire Season • Summer Tires
Tire Diameter • 15 / 16 / 17 / 18 / 19 ”
Profile Width • 195 / 205 / 215 / 225 / 235 / 245 mm
Profile Height • 40 / 45 / 50 / 55 / 60 / 65
Tire Speed Index • V (up to 240 km/h) / W (up to 270 km/h) / Y (up to 300 km/h)
Load Index • 87~100
Maximum Load (per tire) • 545…800 kg
Method of Sealing • Tubeless
Tire Construction • Radial
RunFlat Technology • No
Studded • No
I will share more info after I get mounted…ok, finished…sorry..:bch:
Specs:
Load Index • 87~100
Studded • No
