barbagris
Mad Scientist
- Joined
- Aug 1, 2010
- Messages
- 12,988
- Location
- On the verge of insanity
- Ride
- 1979 Guzzi V1000G5 - 2018 KTM 790 Duke
Decided to start this as I'm interested in reading FEEDBACK from folk using a PC5/PCV - especially if they're using AUTOTUNE.
And yes I know about Tuneboy and TuneECU (I use TuneECU). And Dobeck. And yes - I know getting Wayne (or other Dyno Tuner) would be better - But there are none anywhere near me. The nearest one I'd trust is in the UK.
I'm particularly interested in Autotune experience. Moreso if you've set it to produce a different map for each gear. Seems to me you could set the bike up to run hot and wild in the lower gears then lean out in 5th when cruising for example.
