Plug replacement- NGK or E3 plugs
Venus2050
VIPERMAN
Turnersville, New Jersey
2008 Rocket III Touring
On the subject of spark plugs.
Has anybody replaced the standard
NGK DPR7EA-9 plugs with E3.36?
If so, did you see any radical change in performance or even mileage?
Just looking for some feedback before I grab the plug socket wrench.
Scot,
Thanks for your advise, didn’t think there was a noticeable improvement with E3’s.
Any decision yet on the Rivco Bars?
How difficult is it to do and what tools do I need to change the spark plugs. The dealer is claiming that it takes two hours to change them
Depends on whether you still have the stock intake maze on the top of your engine. If you do not, takes no time at all.
RamAir on the top. No stock intake maze. Can you describe the procedure briefly? What size socket to I need? How do you hold them straight to thread them in?
The only way I've found, is to use the spark plug socket that comes in the Triumph tool kit. It's stamped steel, and thin enough to fit down in the hole. I have to use some duct tape, to hold a socket onto the spark plug socket, and an extension. The plug socket (at least mine) has a piece of rubber in it, to help hold the plug in place. "BE SURE TO BLOW OUT THE SPARK PLUG HOLES" before removing them. Trash can accumulate around the plugs and you don't want that stuff falling into the cylinders.
Raise the tank
Pull the spark plug boots off - be a little gentle, don't have to baby them but don't yank them off.
Can't remember the socket size off the top of my head, but you'll need an extension
I usually look down inside the hole for junk that may have gotten in there before i pull the plugs (so nothing falls in the head). Sometimes even a good idea to give the hole a shot of compressed air to blow out any small crap before pulling the plug.
Remove the old plug. ( I'm a little....OK....a lot OCD and I number the box for which cylinder/plug I'm changing and put the OLD plug back in that box so I can have a historical record of how things looked at that mileage in case I need to start tracking a possible issue related to that plug at a later date.)
Either use a spark plug socket w/ a rubber insert or (what I like to do) get a small piece of rubber hose that fits snugly - not necessarily tight, but enough to hold the plug when dangling) over the insulator of the plug for installation (this will let the plug kinda hang and when you twist the rubber, it will spin the plug and allow it to start in the hole without much force behind it - so you can tell if it's going in the hole easily or trying to cross thread. Spin it until it stops and the plug will be installed. If it doesn't want to start, simply move the hose at a slightly different angle to engage the threads.
Use the socket and extension to snug it down. DO NOT OVERTIGHTEN. I personally don't use a torque wrench I just make them snug. Good idea to put a little dielectric grease on the inside of the boots to prevent them from grabbing the insulator and making it easier to remove at a later date. They actually have little single use packets at the auto parts places just for this.
Reinstall plug boot and move on to the next one.
Lower tank, tighten, and enjoy.
I usually do them in pairs so I can move both plug wires for that coil out of the way to make it easier to get at things. Won't even hurt to pull all six and get them out of your way as long as you pay attention to where they go and put them back in the right place.
BTW, most plugs are pretty close to being gaped correctly, but I always use a "gap checker" to verify prior to installing. You can get them at the auto parts place for pretty cheap too.
18 mm 3/8 drive deap well socket or as cooter pointed out. No other spark plug socket will fit in the hole of the cam cover. I know why did triumph do that. Anyway I loosen plug reach in there with a pair of hemostat's grab old plug out. Now here is the tricky part put new one in you can use the same hemostat's or a piece of vacuum hose the lower the new one in. 20 minutes your done no beer. Add 2 hours if beer is used. Well so the wifey don't catch on use vulgar language so she leaves you alone
