Rusty:
For certain the cat box is heavy. I shook Bart's in hopes of hearing something inside move around but I heard nothing. They must use a porcelain, palladium plated, honeycomb substrate. Bart's really don't sound much different with the stock pipes and no cat box, maybe a little growl, that's all. Bart told me the Triumph bypass was the least expensive of all of them. He had the dealer do the install, smart guy.
It would be fair to say that if indeed the braid was tinned, it would seal itself or become soft enough to conform to the viods between the spigot and mating pipe at running temperature. Normal solder, lead/zinc becomes soft and pliable at (If I remember correctly) 700 degrees farenheit and liquid at 900. Even if it became liquid, the braid would hold it in place, effectively sealing the mating flanges. Neat idea. Of course different alloys of zinc and lead can raise or lower the two temperatures. I'm not familiar with the EGT on a 4 stroke but I do know the operating temperature of a 4 stroke diesel on the exhaust side can run from between 700 degrees to over 1200 degrees depending on the load the engine is encountering.
