Here are the part numbers used for the warranty claim on my rattle. Some are are to make out from the carbon copy and handwriting. I'll hope for the best.
9--------- T1260209----------- Seal
1--------- T1260079----------- Seal Cover
2--------- T1141126----------- Sprocket
4--------- T3050062----------- Cup Screws
1--------- T1142047----------- Blade
1--------- T1142050----------- Blade
2--------- T31550130 ---------Bolt
2--------- 3550029t0301------ Washer
1--------- T1140187----------- Gasket
1--------- T1140180----------- Tensoner
1--------- T1142030----------- Chain
1--------- T1140031----------- Sprocket
1--------- T1100045----------- Key
2----------7100039-t0301----- Clamp
1--------- T3050061----------- Cup Screw
Hope this helps. Please be advised that my water pump was also replaced under warranty and some of the gaskets, washers, and screws may pertain to that install. Your dealer should be able to sort out what is what.
As best I can tell, what you listed breaks down as follows:
Micro
Fische#--QTY-------TPN-----------------Description------Cost------Total
#2---------1---------T1260079-----------Seal Cover------$32.76---$ 32.76
#3---------9---------T1260209-----------Seal------------$ 4.17---$ 37.53
Micro
#3---------2---------T1141126-----------Sprocket--------$67.34---$134.68
#6---------1---------T1142030-----------Chain-----------$96.40---$ 96.40
#7---------1---------T1140031-----------Sprocket--------$58.31---$ 58.31
#8---------1---------T1142047-----------Blade-----------$30.66---$ 30.66
#9---------1---------T1142050-----------Blade-----------$79.86---$ 79.86
#10--------2---------T31550130 ---------Bolt------------$ 2.69---$ 5.38
#11--------2---------3550029t0301------ Washer----------$ 0.73---$ 1.46
#12--------1---------T1140180-----------Tensoner--------$88.17---$ 88.17
#13--------1---------T1140187-----------Gasket----------$ 1.80---$ 1.80
#15--------1---------T1100045-----------Key-------------$ 9.03---$ 9.03
TOTAL PARTS---$576.04
The rest are probably for the water pump:
