Actually there are threads in the ears. After you remove the three torx bolts, the idea was to screw one in each ear to jack the input shaft out of the engine case hole. The ears turned out to be too weak. So then Triumph whent to using a slap wrench to pull the shaft out. If the ears break off just toss them and next time use the slap wrench method. Most owners now have new manuals so the manual shows the new pulling method.
Wow, again -- I actually understand, thanks to your wonderful explanations.
Thank you !!!
