Mike Rocket
Rocket 3
Yes the pipe on the bottom is the supply to the pump it runs from the front port on the tank and picks oil up from the rear area.
The scavenger pump return pipe comes from the rear up and forward a little and dumps on the baffel plate running across the top of the tank.
Just so people know the oil non return valve turns into a one way flow valve upon start up.
Thanks warp9.9
Your drawing shows it much clearer than mine. It looks like the curved end of the pipe will always be submerged in oil as it is curved down. Any oil above the pipe will gravity feed to the pump/sump but only to the level of the cranked end of the pipe, so it looks like Triumph have designed in a safety feature so you can't completely loose all of the oil due to leak down.
