Off For Some Surgery.....
Money well spent I reckon mate. Spent a few hours with a local bloke here (looking at his mates Valiant for sale) He has a 1997 Harley Softtail that he's spent over $26,000 just on the donk. Blew up after 2,000klms so had to just about do it twice. He took off from the lights and I was surprised how sluggish it was ..made a sh!tload of noise but my Rockets heaps quicker. I had to throttle off or would have run up his arse. He's spent more on his engine than my bike cost new
Sh#t photo but I saw this tonight nice paint, I asked if it was so called (factory custom paint) no such thing really is there? The pirate riding it said yes it is a CVO road king. $47000.00. Expensive paint. May be Ponters will get what he wants for his Rocket. Some blokes have a lot of money to throw around
mittzy and mine to compare in case your wondering about ripples its the smoothing setting is 5 on mittzy while is on 2
Tony i have Nevs street cams what cams did you use ? mine is a little stronger till around 5500 rpm, im using tune boy Nev gave me the option to use PC3 witch the bike had when i bought it but i opted for tuneboy because you can do ignition timing as well
My cams are bigger than yours i am lead to believe, i think issues with the tune
I think you need 23'000 cc to make 220 hp at 800 rpm . yo must mean 8000 . are you shore you'll get 190 lbs torque I have more torque than carpenters 240 pac ,mine was tune for torque because that's whet I asked for from Nev, I think you will get 185 lbs torque
No Pete, My tune will not let me rev past 6600 RPM - there is a glitch with the base tune that Fred is sorting out... That's why I only have 212hp - should be around 220hp when I can rev to 7,400 RPM.
What's wrong that you can't get the rev limiter up to 7500?
Dam should off waited a few seconds
Nev says the rev limiter should not be set higher than 7,400 RPM with stock valves. But my base tune has an issue.
But it will be sorted soon.
I am sure Freddo will sort it out. The tune ECU will not allow over 7000 normally. Thats why I use tuneboy for this sort of job. Do not worry Kel, what is happening on the other side of the country will not effect you.
