tdragger
If you have no engine light, there should be no sensors bad. If you have no spark, then the issue must be one effecting all coils, power supply is the most obvious. I have had these bikes "turn over like mad" and still not go, check battery /coil primary voltage when cranking. Does it go with a jump start? Good luck.
Thanks, Neville. No joy when trying to jump start. I'm a bit leary of checking voltages due to my lack of experience. Hopefully the professionals will find it right away.
