Seriously, if you are going to use Tuneboy, then get hold of Wayne at Tuneboy and get him to sell you a base tune with the MAP turned off. Get your tuner to look seriously at the ign tables. The ones in the older model tunes are a guide at best. TTS have done very basic work on the ign on all the tunes I have seen. Fit a high flow fuel pump. Get the bike tuned on a dyno where one can monitor mixtures etc. Bear in mind that the advertised boost is something like 11psi, but each kit I have seen has over 17psi. It will be easy to wreck your engine if not careful with the tuning.
