Need some help
Found one on flea bay which i would rate about a 7 out of 10. Im thinking of gluing a piece of plastic with a few holes drilled through it. I will use a few zip ties wrapped around frame through the holes. I want a little slack so i can take over off to dork with the obdb port but still not loose the cover at speed? Thoughts? Suggestions?
As I said, the third mounting peg (the rearmost one) can be drilled through easily. Make a small hole to make sure it doesn't seriously affect its structural integrity and thread a ziptie through that and loosely around the frame. You can easily detach the panel and lay it on the passenger foot plate if you need to get under there, and if you need it off, snip the ziptie and add a new one when you reattach. Works perfectly.
That's the pretty common fix. Looks like this, works like a champ.
bob
