blip
So this is a little off topic but close enough that I'll post it here rather than it's own thread.
I have reason to suspect my TPS so I plugged in tuneECU and it showed as 0.59 to 0.60 for the primary TPS voltage and 0.70 to 0.72 for the other. The fluctuated between those limits.
The other thing that fluctuated was my throttle position it would sit at 1% and then hit 0% occasionally and back and forth this is on the main diagnostic screen.
I know from the manual that I should TPS reset but I don't have dealer tool and the first step is to close the throttle position using a button in dealer tool. Does anyone know if TuneECU can be used for this adjustment? Also ... is the fact that my voltage is fluxuation sign of a bad TPS? (I hope not cause laconia is only 7 days away and it is minimum 10 for a new part
