Kenneth67
Sarcastic Greasy Toilet Paper
Hi guys, I need a little help with my ISCV if anyone wants to volunteer?
Basically the bike will run fine with throttle open a shade even just 2%, but will not idle. Just bogs and dies.
I've been reading on here about how many others have issues with TPSs and so forth.
I have;
1. Reset ISCV - primary TPS set to 0.60v and then adjusted ISCV until TPS read 0.72v. No difference.
2. Sprayed WD40 in under ISCV rubber boot and all in around the throttle springs etc. No difference.
3. Replaced primary TPS with new one, set to 0.60v etc etc. No difference.
4. Replaced ISCV with new one, set TPS to 0.60v and then adjusted new ISCV until TPS read 0.72v. Also ran the ISCV test in tuneboy. No difference.
5. Replaced MAP sensor with new one and new vacuum tubes. No difference.
6. I run a PC5 so I updated the firmware and reloaded the map. No difference.
7. I reloaded the ECU map and checked idle speed setpoint. No difference.
The bike ran fine for years and suddenly one morning this issue happens.
I'm all out of ideas at this stage but I did watch the ISCV when running and it doesn't do a whole lot.
I expected it to extend out a little to catch the revs as I let go of the throttle, but it doesn't.
Can I ask someone to make a video of what their ISCV does during startup and idling, especially after blipping the thottle please?
So I can compare. ANy volunteers?
Thanks
Ken
I have;
Thanks
Ken
