xlr8tion
Turbocharged
I would check the final drive first even pull it as it is easy. Plus you can lubricate the splines and inspect everything there. If you can pull the rear wheel you can pull the final drive out.
Speaking of bevel boxes..WHAT THE HADES is the hex size on the Fill plug...Doing some insomnia wrenching and my Toolkit is missing and I have searched high and low on forum for the mm size?
It looks much larger than my pathetic set that stops at 8mm....
Ah...back to bed....At least I did not snap off the dreaded drain plug!
Thanks guys!
Cheers...Greg
