Lights, dash but no spinny spinny.
Next question is, where are the grounding points? I know there's one on the starter, one on the battery, any more? Might just make my own.
i think that you grounded the starter relay ? now that does not mean that you have a ground problem it means that grounded the same terminal that the ecu grounds after it receives a signal that the safety's are ok. safety's = neutral light, side stand switch, clutch switch, starter button
if your clutch switch is malfunctioning you can try to start by letting out the lever while holding starter button in,
if it is not the clutch switch then hold clutch lever in press the starter button hard and wiggle it to see if it will start.
hth
do you have a neutral light?
have you tried it with kick stand up?
Thanks Turbo, that's some solid info. Tuneecu still isn't connecting so I guess the ECU isn't powering up. Clutch and side stand switches are next in line for examination. I have a neutral light, I did try with the stand up and the clutch in. All the relays (two on the right and 4 on the left) have all been checked and are fine for operation and continuity. Like twat I forgot to bring the Noco in to up the volts a bit when starting. Also, I'll try what you said with the clutch and starter.
i think that it is time (for checking purposes) to take a battery wire with 20 amp fuse and go from bat to the lights fuse to see if everything works.
also when you try to connect tuneecu make sure the ignition is on b4 trying to connect tuneecu.
Follow your negative battery terminal wire to where it's grounded to the frame. Clean and retighten that connection. There is NO ground on the starter, the starter case is grounded to the engine. There is ONE power lead from the battery + side to the starter thru the starter relay and solenoid.
Ok, next step, voltage check on fuses.
1 13.26v
2 13.03v
3 13.03v
4 12.9v
5 12.19v (this one if from the ignition switch)
6 13.16v (to EMR)
7 13.16v (fan)
8 11.96v (ACC)
9 12.5v (from ignition)
10 12.3v
Main fuse 13.07.
Some pretty ****ty variances there, ideas?
that looks good on fuses
but what happens when you put a load on it like pushing the starter button?
i may be repeating have you tried to put a 12 volt jumper wire to the outside terminal of the #2 coil?
if you have an old dwell meter you can use that to see if the ecu is grounding the coils to make a spark?
check crank sensor on the rear bottom of the engine ? may be broken*wires disconnected.
hth herman
Well, it's not the ignition switch, just replaced it with a Just rockets relocation kit. Meh.
you have been messing with these problems for a about three months what a bummer.
i suspect the problem is on a purple wire that makes aq junction under the tank and there is a cure for this problem/corrosion it is called the @Rocket Scientist relay cure and has had success several times.
if you are tired of guessing you can call me with google meet and i can work with you to get this fixed.
520/649-1342 this is my transmission shop and i use the wifi router so i do not use up my data on phone.
shop hours about 9:00 to 5:00 monday-friday
Thank you, that is extremely kind. I do suspect something might be up with water ingress, last time I used it in the rain, the main beam indicator (not the actual headlight) came on and wouldn't go out for a few days.
If the download is not completed, you can disassemble and reassemble the entire motorcycle, this will not help. Take a laptop with Windows, Tuneecu, Lonelec cable, battery charger, DO NOT PULL OUT THE FUSE ON THE HEADLIGHTS (in certain cases Tuneecu does not connect), download the map and only after that the ECU will control the engine as it should, spark and fuel in time.
