Lifting both wheels off ground using Becker tecknik centre stand
Cityflyphil
Standard Bore
T rocket 3 classic
Hi guys I’ve purchased a Becker tecknik centre stand and can now lift my rocket so the rear tyre is off the ground.
The BT website with the use of wood I can get both wheels simultaneously off the ground .
I’m a bit thick .. how and where do you put the wood for this to happen , pics would be good . Im grateful for your replies .
Thankyou
Tripps I recommend the Becker tecknik centre stand. Go to their website and give it a look. All you need to make sure is the you get the correct one for your bike. The engine mounts under the bike has a hold either side it’s either a 8mm or 12mm hole. I have a 2009 rocket classic so mine is a 12mm diameter. It’s very easy to assemble disassemble. I can now lift my rocket using this stand so both tyres come off the floor.
That was a joke.
