Lift
I use a Titan air operated lift. Works well enough
https://titanlifts.com
Morris,
You made out like a BANDIT!!!
I happened to run across this Titan and was able to determine its cost.
No wonder they keep it such a secret on their site - it goes for $1900.00!!!
Wholly shxt!!! Not one of them in my future.
I currently have a HF that has a better front wheel chock that shown on this thread and it has an air operated lift in addition to the hydraulic foot pump.
Would like to get one wider to facilitate safer ride-on mounting. I be liking that PBL 1500 so far.
Nice lift but can you get an oil drain pan under the bike without a modification ?
No you can't. I cut part off of a transmission funnel to put under the drain hole as I pull the bolt. It takes a few minutes longer that way but I don't have to crawl on the ground. It seems I remember someone posting about having modified a scissor jack to go on the lift table to raise the bike a little for tire, and oil changes. I wish I could find the thread.
And it is on sale for only 899........
I bought a used air operated lift table from the local bike shop a year ago ,they upgrade their equipment once in a while.
anyway I figured if they use it it must be a good quality lift so I plunked down my $600 and never looked back it comes with so called wings (removable 14 inches platform on each side)so one can ride up and have feet well planted each side while getting the front in the choke as a bonus they gave me a small jack modified to lift the rear or front once the bike is tied down so I think any small floor jack can be used with a simple adjustment so far so good without it I could not have done the output shaft bearing replacement!!
