Tal
- Joined
- Dec 20, 2015
- Messages
- 5,887
- Location
- Christchurch, New Zealand
- Ride
- 2021 Triumph Rocket 3 GT.
Triumph Rocket 3 TFC Specifcations
NEW ROCKET 3 TFC
Engine Type Inline 3-cylinder, water-cooled, DOHC
Capacity 2458cc
Bore/Stroke 110.2 mm x 85.9 mm
Power Over 170 PS
Torque Over 221Nm
Fuel system Ride-by-Wire, fuel injected
Exhaust Stainless 3 into 1 headers with 3 exit Arrow branded silencer / CAT box
Final drive Shaft, bevel box
Clutch Hydraulic, slip-assist
Gearbox 6 speed
Frame Full aluminium frame
Instruments TFT multi-functional instrument pack with digital speedometer, trip computer, digital tachometer, gear position indicator, fuel gauge, service indicator, ambient temperature, clock and rider modes (Rain/Road/Sport/Rider-configurable) – Triumph TFT Connectivity System can be added
with accessory fitted Bluetooth module
Swingarm Single-sided, cast aluminium
Front Wheel 17 x 3.6in cast aluminium
Rear Wheel 16 x 7.5in cast aluminium
Front Tyre 150/80 R17 V
Rear Tyre 240/50 R16 V
F Suspension Showa ø47mm upside-down 1+1 cartridge front forks, compression and rebound adj., 120 mm travel
R Suspension Fully adjustable Showa piggyback reservoir RSU with remote hydraulic preload adjuster, 107 mm travel
Front Brake Dual 320 mm discs, Brembo M4.30 Stylema 4-piston radial monobloc calipers, Cornering ABS
Rear Brake Single 300 mm disc, Brembo M4.32 4-piston monobloc caliper, Cornering ABS
Seat Height 773 mm
Rake 27.9º
Trail 134.9 mm
Dry Weight TBC
Fuel Capacity 19 L
NEW ROCKET 3 TFC
Capacity 2458cc
Power Over 170 PS
Torque Over 221Nm
Gearbox 6 speed
Seat Height 773 mm
Rake 27.9º
Trail 134.9 mm
Dry Weight TBC
Fuel Capacity 19 L
