My opinion is you had it in the shop for major work they tore her down and thru the diff on the shelf oil got to soaked and fill a area that it normally does not. maybe a sponge type filter in the breather. Fill her with the require amount of oil Measured not well it is up to the fill hole level. Keep a eye on her and thrash her like she needs to know who is the boss. if you actually have a bevel box problem it won't mater a new one is the fix.
I know this is an old thread, but I have a similar problem as the OP. In the last couple days I have seen fluid leaking from the top of the bevel box. At least I think that's what it's called from the searching on the forum here. The bike is a 2017 with about 4000 miles on it. I am the second owner and put 3000 of those miles on. I have not had any work done to the bike so I know it's not a change in oil or anything like that. What would cause it to start leaking like this, and does it even matter? Also, and I don't know if this is connected or not, in the last couple days the ABS light is also on and does not go out when I start to move. I've driven about 100 miles with both the leak and ABS light. Do I need to have a dealer take a look at this, or is it something simple I can do? Thank you for any input.
