RKTNMYPKT
Village Idiot
I installed the passenger floor boards today on my Roadster.
All in all it was a pretty easy installation, except for a couple small glitches and one scary moment.
The scary moment came when I used a small screwdriver to remove the small D clip that holds the pivot pin in on the peg. Boing!! the thing flies off hits the garage door and lands somewhere on the garage floor
fortunately I found it after just a few seconds of frantic searching. I used needle nose pliers on the next one....
The only difficult part was after installing the foot board I found that it flopped around because it was lacking the cam tensioner that the original peg has, so I took it back off and installed a "D" washer that came in the kit, it took a little time to get this spring loaded washer in place and line up with the holes so I could reinstall the pivot pin.
But I think in the end it turned out real well.
Materials
Front Splined Adapter Mounts
Item #8808
Premium Floorboards for Driver or Passenger (pr)
Item #4351
Tools
Needle nose pliers, 1/4" allen wrench, tapered pin punch (to line up spring washer with holes) Blue thread locker
Time about 1 hr
D washers
Materials
Item #8808
Item #4351
Tools
Time about 1 hr
D washers
