Kuryaken ISO Grips 2014 R3T
Double check there aren't any small screws up under the rubber of the clutch grip where it meets the switch housing. From memory there were 2 or 3 on my R3T heated grips when I went to remove them.
Much swearing until I sussed they were there. Then much kicking of one's own arse :oops:
Great advice, slipped a screwdriver between the grip and the handlebar, a little squirt of oil, a little twist and off she came. Total of 30 seconds I'm sure. No small sets crews to worry about.
Thanks again
ISO grips are installed.
Another tip; if you don't want to glue the clutch grip into place.
I found that if you put three evenly spaced stripes of electrical tape on the handle bar and then carfully twist the iso grip back and forth until its in place you dont need to glue it.
I had the grip sliding so I removed the 4 alen screws and drill taped the end cap the handle bar is already threaded .no more issues with grip moving 20141101_140844.jpg
I used stainless steel screws and i nicked the screw to use it to tap thread into the end cap as the tap point was too long before it would start to tread the hole , you only have 4 mm to work with
Thanks again
Your welcome @Dawg68
Nice one....
I also added the throttle boss to the ISO,took a little work but works good. image.jpg
Nice one... You also went with @neveragain idea... Stock bar ends. They were a little bit of a pain to install but totally worth it because it stops the slop on the throttle
Two thumbs up mate.
For the record in case anyone is unsure, the heated grips are screwed into place (I kind of like that, no messing around with glue) but the stock grips without heat are just a rubber grip that is slid onto the bar. I put the heated grips on (bike came without) and I chose to just slice up the original rubber grip.
