jars n pods
I will post a link for you when I Finnish work guys no problem it's on eBay I will be home in about an hour
Ish I went a different way with my bearclaw although untill recently I had it on the trick to getting it on is as Canberra said twist the top of back one about 1/8th of turn to right and also I used a 5 mm bit of nylon to make a washer behind the rear mount on the tank then when putting it on just start the threads loosely wiggle it in line with the rubber mount at top and tighten the bolts, worked for me. Getting back to cutting it I have cut more away cos I am getting the flip K&N embellishers when he finnishes making them and also the covers, should look good will post picture in morning when I get home from work,
oh and thanks for the link to the trim mitch is that where you also got the chrome trim from
this is for the chrome trim mate
TRIUMPH Rocket 3 III motorcycle 2008-11 Chrome TRIM | eBay
yeah i want to get the dresser caps from flip also so i may take a little more off yet maybe not much just enough to give a glimps of the cap but ill see how i feel when i get the caps because i am rather chuffed with the claw as it is
Just an idea I thought of wit yours cos I do lithe way you cut it, have you thought about maybe outing out section where it covers the top of the filter still leaving the edge you so nicely cut and put some mesh behind the holes so you will be able to see the tops thru the mesh, could be a nice effect?maybe, anyway just a thought for you
Yeah that's not a bad idea either . I'm thinking of buying another claw to play with just to see what I come up with mainly just out of boredom lol but I like to play with stuff like that
I have aspire on the way from NCY from memory it cost about $90 give or take dollar do you should ask for Jason on spares their numbers 0011 1 760 432 9501 from a home phone or mobile it is not expensive, their website is good but Jason will look after you even better some part he has got for me arn't even on the web site, it doesn't hurt to ask
And they would be open, about now it is 5 to 11 in the morning there
Teach me to go to bed and leave you guys up on your own!!!
Hanso, did you say you got a spare bc from NCY?
