Easy install Jardines
Just an easier way to install Jardine pipes on a Rocket 3
Remove all the parts from the box and plastic wrap package.
Place all parts on carpet or cut open box and use that.
Take the header and fit it to the chrome right side muffler, making sure it will slide on.
Take the header and fit it to engine and snug bolt. make sure that the header does not contact any part of the engine. I used a brass bar and tapped the end of the header for a nice ring tone. If it makes a thud sound the header is touching something.
Remove the header and install the chrome heat shelds. I installed the upper hose clamps with all the heads toward the front end.
The lower hose clamps on the front two headers shields I installed the clamps with the bolt facing down.
The last lower heat sheild hose clamp I nstalled it facing up.
Snug up the hose clamps to allow them to set the shape of the header pipe.
Loosen the hose clamps slighty so they can be moved by bumping them with a brass bar.
Install the header on to the engine, as you tighten up the header flange bolts make sure all hose clamps are not hitting the engine block. Just tap them with brass bar to clear engine.
Torque headerbolts to correct spec. then adjust hose clamps to where you like them and tighten. When tight tap end of header with brass bar for clear ring.
Install both muffler heat shields on to the mufflers. Tighten hose clamps to set the shape, then loosen. I mounted the hose clamps heads down.
Remove the reat foot peg and remove the old muffler brackets. Loosen the chrome covers that the foot pegs are attached, do not remove the cover
Use High temp copper RTV, coat the inside of the mufflet inlet with RTV then apply a thin coat to the outside of the header.
Slide the muffler onto the header,once started take the foot peg and put it through chrome cover then through muffler bracket, then througn frame..Start foot peg nut. when finger tight use a small rubber mallet and tap under the muffler where it goes into the header. This will set the correct depth of the header into the muffler. Tighten the foot peg nut and the 2 chrome cover screws
Place the T-bar clamp on the cross over pipe. Remove the other side rear foot peg and loosen the chrome cover screws. Remove the old muffler bracket.
Coat the muffler inlet with the RTV sealer, just start the muffler on the cross over pipe. Put the foot peg into chrome cover then into the new muffler bracket and into frame, start foot peg nut. Snug foot peg nut finger tight
Tighten the T-bar clamp over the muffler/crossover pipe. Tighten foot peg nut and chrome cover screws
Start at the headers and work your way all the way to the back checking tightness of all nuts, clamps , bolts and screws.
wipe down with all chrome with a good cleaner. I used 99% IPA.
Then install the last 4 pieces of the chrome. 3 header and the Y pipe cover with the screws and washers. wipe those down
You are done.
