Hi not the best way to do this job as the sump is not the strongest casting in the world. Better if you can use the lugs as well near the back of the engine the ones with holes in them just at the bottom of the frame buy the starter .
As you need to lift the bike quite high to remove the wheel and if you are removing the swing arm it would be more stable as well.
But you could if you had to . tie down the front as well to make more stable
