DavidR3R
.060 Over
Hi guys, took my 2015 Roadster to the dealer because it was surging on a steady throttle at 4000rpm. The revs would increase and decrease about 500rpm either side of the 4000 mark without the throttle being moved. Only noticed it when the bike was run in and I was regularly up in that rev range. Haven’t noticed it happen at any other revs.
Anyway, got it back yesterday and they said they’d adjusted a few things – and didn’t they just!
It now idles at 1200rpm for about 5 seconds on a closed throttle before dropping back to the proper idle around 900rpm. This is a problem because the bike isn’t slowing down properly when the throttle is first closed which makes it difficult to judge when approaching traffic or filtering and generally makes it hard to ride smoothly.
The other thing I’ve noticed is that all the slack has been taken out of the throttle. I’ve got the OEM heated grips so I know from this forum there needs to be some slack to stop the cables wrecking the grip and leaving me stranded, so that’s definitely got to be sorted.
So…anyone heard of this 5 second ‘high idle’ before it drops to the ‘real’ idle’ and is the high idle linked to the lack of slack in the throttle cables?
If it’s just a case of adjusting the slack back in I can do that. The obvious comment will be to take it back to the dealer but I don’t trust their mechanics and I’d rather not if I can fix it myself.
Appreciate your help!
Dave
Dave
