How to remove secondary plates and turn them off in tunEcu?
Msmitch459
msmitch459
CedarSprings, Mi.
2015 Roadster
do i just remove the plates and turn secondary throttle off?
What would be the pro's and con's of doing this? Does setting them at 100% in all the rows in tuneecu accomplish the same thing?
Thanks,
Dean
Thanks,
Dean
Don't know of a con. So one might but I removed the secondary plates on my 09 and ran it that way for years without any problems. Difference was, HansO proved the tune. He, Warp 9.9 and others helped a ton of us out over the years. I guess they've stepped back a bit.
Why do it? Performance. Try it and you'll see.
I don't know if it makes a difference removing the plates or not after setting them all at 100% open. But why leave something on if you're not going to use it? And, once you remove them, I doubt you'll ever want to put them back on again.
After recently installing the ramair filter, I'm not fond of the sound of them clattering. I wonder if I set them to 100% in all the colums would stop that sound. Should eh?
