barbagris
Mad Scientist
- Joined
- Aug 1, 2010
- Messages
- 12,988
- Location
- On the verge of insanity
- Ride
- 1979 Guzzi V1000G5 - 2018 KTM 790 Duke
Has anybody ever opened up a fuelbot?
Any idea how to open one up. Mine has a water ingress issue.
It keeps trying to reset and has changed to miles. The bike had to sit in rain at the ferry port and despite current sun all it does is condense inside. I thought I might try filing of a corner and see what happens - but if there is a better way - thought somebody might know.
The Bot changes and resets or lights all white or no light or asks for intervention. The capacitive switch is working overtime.
When it does a reset the OEM speedo/odo stops working. So it is knackering the pulses from the speed sensor. I suspect a false earth caused by water in the box. If all else fails I'll cut the wires to the fuelbot. But would rather not. The bugger is I am at mums in the UK with no tools near enough.
Please - if poss let me have info by email chrisjw@protonmail.com as I am having massive issues getting a stable connection to the web. Also if anybody can confirm me the wire colour from the Fuelbot that attaches to the speed sensor wire and the colour of the triumph speed sensor wire it would help enormously.
Chris
Chris
). Mind you at 1% throttle god knows why the ECU cares. UK traffic - I keep forgetting how much there is.
) - and then gets cooled and doused in water all at the same time. It then seems that the bond glass/plastic (JB weld) can fail. As in my case this results in the glass actually being covered by water - the cooling sucks water in.
