Remove outer hex head that holds the weight on. Then there is two screws in the throttle housing. Loosen up enough that you can split the housing and slide out the grip.
There are two set of screws. Outer ones (Torx head) and two inner ones (Philips)
Which ones should I loosen up?
Thanks
