Zen2osho
.040 Over
After changing in the front forks (both) and took the bike for a ride?the suspension is harder than before and the handlebar bounces small when the bike enters potholes??
Measured 667 ml as mentioned in the manual and poured d oil . Will the suspension get soft on riding few miles ????
Did the spring part etc from the front top?
Loosened the bolt on the bottom of the fork drained the oil? Filled oil from the bottom hole only.Fitted the oil seal , dust seal and retainer.
Is it ok or the springs etc nèed to be removed for the oil change??
Inputs pls??
Inputs pls??
