Gas gauge doesn't work
canecorso
The custom seat man
Thread starter
Toronto, Canada
2005 Triumph Rocket 3 Classic
I don't understand I push down on the float and doesn't seen to move and I don't feel like taking it all apart again, is there any one on the forum that as unstuck the float from above and share how they done it? maybe I'm just being too carful for the fear of breaking it or not doing it proper with out damaging it.
if I can get it unstuck and it still doesn't work then I'll order another sender and only take apart once to put new sender in, but I rather get it unstuck from top to see if it works or not. Has any one gone through this and can help would be great.
idk
Maryland
Royal Enfield Bullet
It's either stuck or the float has a hole in it. It is easy to get it stuck when installing it, so you may have to do it again.
If it has a hole then empty the float and fix the leak with Araldite
canecorso
The custom seat man
Thread starter
Toronto, Canada
So it's not possible to in stick it from the top by putting long scew driver in and try to push out towards the right?
Or will I damage it by forcing?
I'm trying to understand how its stuck is it tight from has pump and float that can be tight against bottom of tank and pump?
If I do take it apart again what am I doing wrong too install because last time I put it in it was also stuck and I thoy I was extra careful and seems again stuck, what am I doing wrong?
So when I do it again I know what to do?
TURBO200R4
stand up straight and grab the world by the a$$
TUCSON AZ
07 rocket III classic
I taught i might help so i have some probes and i tried to hook that rod/float but could not get a hold of it.
I have almost a full tank of gas.
The only thing that i acomplished is i have a real clean tank.
Kojack1970
Turbocharged
South Grafton, MA, 01560
2016 Rocket Roadster and 2000 HD Fatboy
If it were me, I'd drain the tank and take it apart to check for holes in the float and make sure it goes back together unstuck.
my 2 cents.
AND... I'd bend the float arm down slightly so the **** gas light doesn't come on with 50 miles still on the clock. Annoying...
canecorso
The custom seat man
Thread starter
Toronto, Canada
So those floats are hollow , this is my second time putting it in wrong perhaps it does have a hole in it that how it got stuck. Going for a ride Saturday I will take it all apart Sunday and put my classes on to check for holes. And then check that sender to see if I'm getting 12v if not I'll just order new one, hopefully if I do need a new sender it's not too difficult to install. I'll keep you guys posted thanks
warp9.9
Pocałuj mnie w dupę
Forest City Illinois
07 Rocket
If you never updated the sending unit which got changed in the update kit then its time to anyway. At least thats what I'd tell myself to justify it in my mind :D
Here is a larger shot of the tank internals.
canecorso
The custom seat man
Thread starter
Toronto, Canada
Do you happen to have a video of you installing one? If I do install new one you still need to bend it? And if I'm going to take it all apart again is there a need to put in a new gas filter as well?
AdBlock Detected
I've Disabled AdBlock
