r3badboy
- Joined
- Mar 28, 2015
- Messages
- 369
- Location
- New Zealand
- Ride
- 06 Rocket 3 & all years parts built R3 & 06 flood
Not compatible bud, you would need to change wiring loom & ecu with the gauges & gear position sensor...Hey guys, I too just recently got a 05 Rocket III and have the same thing in mind about getting a fuel gauge. I was looking around a bit the other night on the Internet and ran across pictures of a set of gauges that said it was from a 2010 Rocket . They are similar in appearance to the O5 gauges but they are black Faced and there is a digital display on the tack like there is on the speedometer. From what I read the digital display on the tack had a clock and a fuel gauge. Can anyone verify this ? And if this is correct are these gauges compatible with the 05? The other question I had was do they all use the same float sending unit ? or do different years/models have different ones? . Thanks for any info you guys can provide.
My understanding anyways....I'm sure others will elaborate
